Author Topic: Transformer output impedance  (Read 798 times)
Offline fonographTopic starter
  • Country: at
« on: August 26, 2018, 06:22:58 pm »
Does 2:1 step up transformer double or quadruple the impedance? I am not sure but I think I read in book that it quadruples for every doubling of voltage,but when I think about it some time later,it seems wrong becose if we send same amount of power through double voltage,we only need to halve the current so just doubling the output impedance should be enough to avoid breaking the law of conservation of energy.
Offline HB9EVI
Re: Transformer output impedance
« Reply #1 on: August 26, 2018, 06:55:18 pm »
Keep Ohms law in mind:
sqrt(P/R)=I
and
sqrt(P*R)=U
resistance/impedance and power are in exponential relation
so a turn ratio of 1:2 leads to an impedance ratio of 1:4
The following users thanked this post: fonograph
Online David Hess
  • DavidH
« Reply #2 on: August 26, 2018, 06:56:14 pm »
The impedance is the voltage divided by the current.  A 2:1 step up transformer doubles the voltage and halves the current so:
2 / 0.5 = 4
So the impedance is raised by 4 times.
  • Country: at
« Reply #3 on: August 26, 2018, 07:00:14 pm »
Ahhh yes  :palm:     I am embarrassed that I made such basic mistake,now it seems so obvious.
