Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
Transformer pinout?
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Transformer pinout? (Read 5694 times)
dog80
Regular Contributor
Transformer pinout?
on:
September 19, 2013, 02:08:55 pm »
I have a small board mounted transformer that I desoldered from a PSU. It has a EEL-16-2005 marking and is probably the same as the one in the middle in this picture:
http://www.it.com.cn/f/diy/058/25/20050825_csdy_bmeng_10.jpg
I want to determine the pinout. I tried to find a datasheet but had no luck.
It has three pins on the one side with a single strand of wire each (guess this is the high voltage side) and there are five pins with multi strand wires on the other side.
I tried supplying 16 volts AC on the high side but it was drawing too much current.
What am I doing wrong?
Logged
mariush
Super Contributor
Country:
Re: Transformer pinout?
Reply #1 on:
September 19, 2013, 02:59:39 pm »
Those transformers are designed to run at high frequency (40kHz-100 kHz), they won't run properly at mains frequency (50-100Hz). It's almost useless to you, it's not the same thing as a regular, classic transformer.
Logged
Skippy
Contributor
Reply #2 on:
September 19, 2013, 07:24:37 pm »
Specifically it's a
Flyback transformer
Logged
Phaedrus
Frequent Contributor
Country:
Reply #3 on:
September 19, 2013, 08:39:10 pm »
The two smaller transformers will be of more use. One of them should be a 1:1 isolation transformer, and another should be suitable for a single transistor forward +5V DC power supply from mains.
Logged
More quotes have been misattributed to Albert Einstein than to any other famous person.
- Albert Einstein
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Transformer pinout?
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
