Are you sure this is just a 1A supply? 2x 5600uF for 1A is ridiculous. The charging current pulses would be very large, likely stressing the transformer core.
What is the point of sense connections, that are not actually used for sensing the voltage, but are just connected in parallel with the main output?
You know, you're probably right about that. I apologize, I may have labeled it incorrectly.
It's from a Circuit Specialists 3003x, so it's more likely
it's a 30v , 3A power supply - after all the transformer windings don't add up to 50v and the two npn transistors/darlingtons should have alerted me that it's more than 1A - you don't usually need two of those for 1A.
Either way, it's still a relatively good example of how relays are used to switch between windings and how the relays are triggered.
I downloaded a bunch of schematics a while ago from their Circuit Specialists website store, back when they had datasheets listed for some power supplies of theirs. Nowadays, I'm not sure they have the schematics anymore.
I wouldn't be surprised if the schematics have some parts incorrectly printed, seems there's a lot of copy and past or at least reusing the same base pcbs between models. They all use the same icl7106 based voltage and current lcd displays for example...
I'm attaching a bunch of other designs I copied back then in case someone finds inspiration from them.
