I've read your original question again, I think now I've got the point
So from what I am gathering, if you stand in your bare feet on a wet floor and touch either of the secondaries of a transformer, current cannot go through you? Because those secondaries are isolated from ground?
No, no current cannot go through you, because the transformers secondary is isolated from ground. The transformer opens the circuit.
You'd have to touch both to complete the circuit?
What exactly is both? If you touch both ends of the secondary of the transformer, yes you'd close the circuit. Not if you touch the primary with one hand and the secondary with the other, because the transformer opens the circuit.
Also if a DC circuit is floating (i.e. no protective earth wired to chasis), and you are in your bare feet and touch the positive side only of that DC circuit, would current flow through you to the ground?
No current would flow, if "floating" means "isolated from ground"
Edit (add more confusion): "floating" does _not_ neccessarily mean "isolated from ground". It often means "a supply voltage measured between two points in circuit, superimposed with an AC or DC voltage and having a conductive return path to ground". In this case, a current would flow through you to ground.
I understand the power from power company is grounded,
Yes, if you touch the live wire, current would flow through you to ground. You close the circuit.
Just trying to understand how a circuit could complete, through a human, through the ground with a floating DC circuit or secondaries of a transformer.
That circuit won't complete, no current would flow. Except for:
- there's a failure in the isolation
- the isolation rated voltage is exceeded
- or other faults (maybe you dropping a loose wire into the circuit by accident)
So the concept of isolation for human safety is to introduce one more point (e.g. the isolation transformer) that opens the circuit in case you accidentally close the circuit using your body. If you don't do any accidents, the circuit is open anyway, so its redundancy for your safety.
