I've run into a small problem but basically things are working almost perfect with the simulation.
Call me cynical if you like but isn't this where you started, three threads ago? In the process of bringing up the voltage, the control section passes through an undesirable state. Can you identify how slowing down the voltage rise is going to change this?
Also, in the present configuration, Q2 will probably not appreciate having 40+ volts shoved the wrong way up its base-emitter junction.
No, completely different approach to the way I'm going about it. I've been trying to work out a way to delay the full on state with a reasonable soft start that works. I came up with something that only halfway worked with a PFET but the charging cap ramped the gate voltage up stayed charged after power off and I couldn't figure out how to discharge it without affecting the circuit in undesirable ways. Having said that, the part that did work, worked well. If I discharged the cap and turned on the power supply, the spike was not measurable.
As far as Q2 goes, I've got one happily living soldered to the underside of one of my supplies and it hasn't failed yet and has eliminated the problem of the shutdown transient. Thanks for pointing it out though, I should probably try and play around with that side of the circuit to see if I can come up with something better there. Some of you guys go way over our heads so that's why this is in Beginners, because I'm not always entirely sure if the things I'm doing are good, bad, or otherwise crazy. Trying to solve the issues with this supply has me learning but I'm not trying to earn a PHD with it, just figure out how to make it work well enough that the several hundred I've sunk into it wasn't entirely wasted. If I keep playing with it, along the way I may just discover why it doesn't work all that well and come up with something that does.
I know this is in several threads and I've been trying to get help to solve the problems and have gotten some good suggestions. Sometimes though I just get "this is a bad design" with no other indication as to why or what to change to make it not so bad. There's a
thread where newbies are asking for a good first build and a sticky to go along with it because there's too many bad designs out there and they (we) don't know where to start. This was my first build besides the ubiquitous 317/337 design and I'm rather proud that my first boards worked with the exception of the fact that I got the footprint of Q1 backwards. Small problem, boards worked. I've decided that since this is a much hated design and no one has really put forward a design that has been asked for repeatedly, that I'm going to eventually fix it and make it work well enough that it gets used without too much derision.
