Hello there,
I need to make an ultrasonic power amplifier. I have looked at class A and B and AB.
I have 150V 7A adjustable PSU single supply, I need to amplify a sine from function generator to 70Vrms 5A or higher amplitude out. That's easy.
My problem is that I want V_OUT to swing really close to V+ and GND, so that V+ can be as low as possible. That way i can dissipate as little heat as possible/high efficiency. How do I design the gain stage to achieve a voltage swing close within the limits of the supply?
Thanks.M
