Hello, I am a long time "lurker" in the forums and finally have an opportunity to put some of the knowledge I have gained from the forum and videos to work. I just ordered my DSO1054Z for this project. Finally have a reason and purpose to acquire my own scope
So here is my challenge... a point of sale (POS) system uses an Epson receipt printer (TM-T88IV). The printer has an RJ11 cash drawer trigger port which sends a 24V pulse to activate a solenoid which mechanically opens a cash drawer. I have tried multiple cash drawers and multiple cables and cash drawer operation is not triggering. So I figured I would create a breakout cable to test to see whether I am getting any signal, bad signal or incorrect voltage, but I don't want to blow up my new scope when it arrives. I also I want to make sure my test protocols are correct.
The RJ11 port is configured as follows: (I have also included a detailed pdf of the circuit and details of its operation)
Pin1: Frame GND
Pin2: Drawer Kick-out signal1 (Output)
Pin3 Drawer Closed / open signal (input) "provides drawer state"
Pin4: +24V
Pin5: Drawer Kickout drive signal 2 (Output) "for second cash drawer if required"
Pin6: Signal GND
I presume I should probe pin 4 to make sure it has +24V. Then probe pin Pin 2 looking for 24V when open signal is sent.
signal should last according to the following calculation found in teh atacehd PDF (2mS x t1) where t1 is set to 100mS in our software
I assume i have to set the scope to trigger so the "capture" occurs. not sure how to do that but I will certainly try and RTFM when it arrives. (if I can avoid the urge to probe!)
Sound about right? Any advice would be greatly appreciated.
