Hey Guys,
First post here, I am just getting into electronics on a hobby level and wanted to have a pick at your knowledge if possible, i purchased a Nixie clock kit off ebay and i was a bit confused as to which way to install a transistor, the little icon at the top right hand corner of the transistor i was assuming was pin one? but it has the two pins on that side are bridged together. But on the board the opposite side if installed that way would be bridged out from the tracks. should i just go by instinct and install it so the bridged tracks and bridged pins meet up?
