Thank you for the precious information, and for the solution.
I've looked at the LM3886 datasheet, in particular to the equivalent schematic on page 7. From what I understand (but please correct me if I'm wrong) I have to "activate" that transistor which has the base grounded, and to do this I have to connect its emitter to a more negative voltage, which is the negative rail. Am I right?
Thank you
