Author Topic: Transistors: Connecting Bases  (Read 11267 times)
Offline Falcon69Topic starter
« on: July 18, 2014, 08:13:06 am »
I am having trouble with a circuit, and I suspect it could be because the way I have the transistors set up.
Just ignore the inputs/outputs, only look at how the bases are connected together in the picture.
Which is the correct way to do it? The top or the one below?
Also, can the emitter of an NPN be connected to the emitter of a PNP, or should there be a diode/resistor in between them?
Thanks in advance for your insight. :)
Jason
Offline Simon
  • Global Moderator
    • Simon's Electronics
Re: Transistors: Connecting Bases
« Reply #1 on: July 18, 2014, 08:18:17 am »
Both would work in theory although if you use one base resistor it needs to be 1/3 the value for 3 transistors. I'm no BJT expert and I'd go with caution and use individual base resistors because unless the Vbe is identical then they won't all come on by the same amount or at all.
« Reply #2 on: July 18, 2014, 08:22:22 am »
Ya, I have them wired like the top.
A single 10k to run 3-4 transistors.  It doesn't seem as if they are all turning on.
So removing that 10k at the power input, and then placing a 10k between power and each base, should allow them all to turn on at same time when switch is hit?
Offline Simon
  • Global Moderator
« Reply #3 on: July 18, 2014, 08:23:39 am »
it sounds like 10K is only enough for 1 transistor so the best wins, you need then 3.3K or better 10K for each
« Reply #4 on: July 18, 2014, 08:27:09 am »
okay, i will try that Simon, thank you.
So what s happening, the 10k is eating up too much voltage, and not leaving enough to turn on each transistor. But reducing that to 3.3k should leave enough voltage to switch each one on at same time?  That makes sense I guess.  But, it sounds like they still may not switch on, unless the vbe is the same, which I doubt they are.
I will wire a 10k to each one, and see how that works.
Thank you Simon.
Offline Simon
  • Global Moderator
« Reply #5 on: July 18, 2014, 08:36:35 am »
you are not using voltage to turn on the transistors but current, you need to know your load current, then your base current (Ib) is Iload/beta of transistor, your base resistor will then be (Vsupply-0.7)/Ib.
The problem you can get with paralleled bases is that if one transitor heats up the base voltage drops allowing more current through so it will take up all of the current and starve the other 2 as they are a less easy path.
Offline Andy Watson
« Reply #6 on: July 18, 2014, 08:37:06 am »
Either circuit should work. But if you are using different colour LEDs expect a lot of variation in light output - due to the different operating voltage of the LEDs.
Offline janoc
« Reply #7 on: July 18, 2014, 08:49:45 am »
Thank you Simon.
Strictly speaking, a BJT turns on with base current, not voltage (unlike a FET). So if you use a single resistor for all 3, the resistor needs to pass 3x as much current in order to open all three transistors (Kirchhoff's law). If your BJT works with a 10k resistor solo (with about 500uA base current), then using 3k3 (or even 2k7) should do it.
However, putting a separate resistor for each transistor is better - the transistors don't have the same beta, so they may need different base currents.
Offline Simon
  • Global Moderator
« Reply #8 on: July 18, 2014, 08:53:36 am »
Could the base/emitter volt,age vary with temperature of the working BJT? like i said i'm no expert on BJT's and I'm wondering myself ?
jucole
  • Guest
« Reply #9 on: July 18, 2014, 09:37:58 am »
This is a really good video which might be useful.
Offline mikerj
« Reply #10 on: July 18, 2014, 09:49:05 am »
Are you simply trying to switch LEDs on and off, or are you controlling the brightness with some external circuit (i.e. instead of the switch in the schematic)?  If you only want to switch them on and off, then why have you chosen an emitter follower configuration rather than common emitter?
Offline mij59
« Reply #11 on: July 18, 2014, 10:45:26 am »
This is a very expensive circuit just to turn 3 led's on, wondering why you want 3 transistors.
The 10k resistors are not needed, it's better to connect a 10k resistor between the bases and ground, so the bases don't float.
The function you need can also made with just one transistor.
Offline Simon
  • Global Moderator
« Reply #12 on: July 18, 2014, 10:59:38 am »
You talking about mosfets not bjt's, remove the resistor and it all goes bang
Offline mij59
« Reply #13 on: July 18, 2014, 11:15:47 am »
Why should it go bang ?
Offline rs20
« Reply #14 on: July 18, 2014, 11:49:31 am »
Woah, woah woah. The BJT does *not* go bang if you remove the resistor, not even close. See attached sim. The top circuit would work perfectly if the LEDs were simple 2V red LEDs, but from context I suspect these are actually LED arrays designed to run at 12V which is why it's not working.  I'm going to continue under the former assumption though.
I'm not advocating this design, but let's actually model what we would expect to happen with the top circuit. Firstly, the LED/resistor pairs will never see more than 5V, so the fact that they're being powered off 12V is weird, they may was well be powered off 5V as well. If you want to fix this, the LEDs should be connected to 12V and switched from below (still with the resistors down to ground for the reason explained below). So from +12V, it goes LED, then BJT, then resistor.
That point aside, the bases of all the transistors are going to have the same voltage, because they're shorted together -- let's say 4V for the sake of argument (probably much lower if the resistor is too large, but that's not my point). Since the VBE of a transistor will stick to a narrow range around 0.7V more-or-less regardless of base current, we expect that the emitters of all the transistors will all be around 3.3V. If the LED resistors are appropriately chosen, this is a perfect outcome, they'll all shine equally brightly regardless of transistor hFE and so on. You do not need the 10k resistor at all, the BJTs will not blow up because the emitter voltages will rise.
In short, get rid of the base resistors entirely (just short them out) and that's actually the best thing to do, not a recipe for a bang. Assuming those LEDs are just single, naked LEDs as opposed to 12V modules.
« Last Edit: July 18, 2014, 12:07:26 pm by rs20 »
Offline LvW
« Reply #15 on: July 18, 2014, 12:22:02 pm »
Perhaps not too important within the context of THIS thread - however, this assertion is not true.
It is the base-emitter VOLTAGE which controls the collector current and NOT the base current (which cannot be avoided).
Physically - it is, of course, the changing voltage across the depletion layer which allows the current to become larger or smaller.
A larger current (like Ic) never can be controlled by a smaller current (like Ib).
This was discussed already several times in various electronic forums.
Offline janoc
« Reply #16 on: July 18, 2014, 01:11:24 pm »
Care to explain (or point me to some place discussing this), please?
AFAIK, for BJTs, beta = Ic/Ib, thus you are controlling the collector current by the base current (current amplification). Of course, in order to get the current flow you need to apply voltages with the correct polarity, but if the device was voltage controlled as you seem to imply, then the OPs circuit would have been working as he had sufficient voltage applied to the bases. It didn't work, because the transistors split up the available 5V/10k = 500uA of base current among themselves and that portion was not enough to keep them open.
You could say that the base voltage was too low because of the large voltage drop over the resistor, but that voltage drop happens because there is current flowing through the resistor -> no current, no voltage drop.
It is quite well explained for ex. here, including what is happening with the minority/majority carriers and the depletion regions: http://ecee.colorado.edu/~bart/book/book/chapter5/ch5_2.htm
Offline David Hess
  • DavidH
« Reply #17 on: July 18, 2014, 01:11:49 pm »
10k is too high a value to drive the three transistors in parallel; with a worst case hfe of 50, the total base current would be almost 200 microamps so the 10k base resistance would have a voltage drop of about 1.8 volts limiting the LED current significantly.
A resistance below 3k would work to drive all three transistors with their bases tied in parallel but there is no reason to use one that high.  I would probably just use another 680 ohm resistor; the value is not critical.
Maximum LED current in this circuit is about 3 milliamps.  Is that what you intended?  One transistor would certainly work to drive all three LEDs.
« Last Edit: July 18, 2014, 01:16:29 pm by David Hess »
Offline rs20
« Reply #18 on: July 18, 2014, 01:19:21 pm »
Good point.
Why not zero ohms?
Offline David Hess
  • DavidH
« Reply #19 on: July 18, 2014, 02:11:09 pm »
Why not zero ohms?
Adding the single resistor may make the board layout easier.  Other than that I do not see any problem with zero ohms.  Sometimes the base resistor and a shunt capacitor are added for ESD protection if the LEDs are exposed.
In other circuits the base resistor might be added to isolate the output of the stage driving the transistor or as a snubber to prevent the transistor from oscillating if it is driving a low impedance load but neither consideration applies here.
Offline LvW
« Reply #20 on: July 18, 2014, 02:13:36 pm »
Hi janoc,
I think, in general we have to distinguish between a simple formula (like Ic=B*Ib) which can be used during the design and other formulas which describe the real physical effects. Of course, Ib is a small (nearly fixed) percentage of Ic - but does this automatically mean that Ib controls Ic?
More than that - for my opinion, even the document referenced by you supports the voltage-control approach. See the following excerpt:
We consider here only the forward active bias mode of operation, obtained by forward biasing the base-emitter junction and reverse biasing the base-collector junction. .......
Once the electrons arrive at the base-collector depletion region, they are swept through the depletion layer due to the electric field. These electrons contribute to the collector current. In addition, there are two more currents, the base recombination current, .....and the base-emitter depletion layer recombination current.
For my opinion. the base current is clearly considered as secondary (not as the cause of Ic).
Here are some other references:
1.) Winfield Hill (Co-author of the popular Horowitz/Hill book), see his post#2 and post#10:
http://cr4.globalspec.com/thread/68055/voltage-vs-current
2.) Berkeley University (see chapt. 8)
www.eecs.berkeley.edu/~hu/Chenming-Hu_ch8.pdf
Excerpt: An undesirable but unavoidable sideeffect of the application of Vbe is a hole
current flowing from the base, mostly into the emitter. This base (input) current, Ib,
is related to Ic by the common-emitter current gain.
3.) Book from Sedra/Smith (chapt. 5)
Excerpt: Basically, the forward-bias voltage Vbe causes an exponentially related current Ic to flow in the collector terminal. The collector current Ic is independent of the value of the collector voltage as long as the collector–base junction remains reverse-biased; Thus in the active mode the collector terminal behaves as an ideal constant-current source where the value of the current is determined by Vbe.
« Last Edit: July 18, 2014, 03:57:45 pm by LvW »
« Reply #21 on: July 18, 2014, 05:12:27 pm »
Hi guys, and thanks for your input :)
The input voltages and outputs (led's in this case) are not important. I was merely wondering about what is needed to successfully drive the transistors when the bases are tied together.  As in my circuit, they are not turning on.  I will post my circuit in the original thread I had started early, as that is the correct place for it.
So it seems that the consensus of everyone is saying to place a resistor at each base of each transistor.
There may be something else wrong with my circuit, but I think I have my answer here. I just need to add a resistor at the base of each transistor or (for layout purposes) divide the 10k by how many transistors (10k/3 = 3K3) and use the 3K3.
Thanks everyone!
Offline Dinsdale
    • pretzelogic
« Reply #22 on: July 18, 2014, 11:24:33 pm »
Your transistors have no reliable bias.  Your bias current is highly dependent on the transistor gain.  Plus the voltage at each emitter is probably highly variable.  You need a resistor divider on EACH base.  Try 5k up and 1k down and adjust from there.
This can't be happening.
Offline c4757p
  • adieu
« Reply #23 on: July 19, 2014, 12:47:06 am »
Seriously, dude? Did you look at the schematic?
They're common collector for god's sake. They don't need "bias resistors". They don't need base resistors at all.
Offline janoc
« Reply #24 on: July 19, 2014, 01:45:06 am »
Hi janoc,
OK, thanks for the references, I am chewing through it (I am a software guy by trade, not EE, but physics and electronics was always my interest). However, as you have said - that's really an enormous overkill for what the OP was asking. Also most literature shows the current-based analysis, using load lines, characteristics, beta and such, so that's where I am coming from.
