ok, this is making me quite annoyed now.
I just received a new order of parts, just to be certain that I had some brand new components to use, including a new 2x15V trafo, a couple of l7912's and l7812s and a couple of diode bridges.
Anyways, I'd start wondering if I'd fried something, so I went to the datasheet for the l7912 and read that it's around 30v max input. Hmm...
I've been messing around with the circuit without a load, so I knew the rectified voltage would be a bit high - and it was about 35 +/- to the centertap ground.
hmmm.. well good thing I got new components.
Anyways, I tried to put a load on the circuit by a 220k resistor from out to ground on each regulator. But the voltages was still high. Hmmm.....
finally I strapped some zener diodes from input to ground on each regulator, which brought the input voltages down to around 26V (+/-) on each input.
Put a new pair of regulators in there, just to be sure - but still no dice. Voltages on the output of the l7812 is hanging very nicely at 11,6v but the 7912 is at 17V!?!?!?
Is this problem showing up becuase of a no-load situation or
