I need help troubleshooting an aircraft-band receiver. It is a kit from Ramsey Electronics known as the ABM-1, which receives the entire aircraft band at once (no tuning). The radio worked immediately upon completion of the kit, but then stopped working after a few days. No sound can be heard through the (confirmed working) earphones.
The schematic is attached. There are four ICs. I believe the problem surrounds U1, the RF amplifier. The reason I say this is because the output pin of U1 is supposed to read 4.7v (according to the manual), but I am getting .01v. The input pin is supposed to be 2.5v, but I'm reading .05v. The power supply side of R1 properly reads 9.0v, but virtually the entirety of the voltage drops across the resistor (instead of about half), leading me to think that the IC side of R1 is getting shorted. Is that correct? If so, how do I find the short?
I carefully checked the board under a microscope and could not see anything obviously wrong. I resoldered all suspicious joints with no effect.
Note that according to the instructions, pin 1 of U2 (the AM detector) is supposed to read less than 0.2v, but it is 3.1v on my board. The other readings appear ok.
Here are the voltage readings on the various IC pins:
U1
2 ground pins 0v
input .05v
output .01v
U2
Pin 1 3.1v
2 0v
3 1.7v
4 0.2v
5 4.4v
6 4.8v
7 4.8v
8 3.1v
U3
1 0 or 8.9v, depending on squelch pot setting (R4)
2 0.2v
3 .08v through 0.9, depending on R4 setting
4 0v
5 0v
6 0v
7 0.04v
8 8.9v
U4
1 1.3v
2 0v
3 .006v
4 0v
5 4.6v
6 8.9v
7 4.5v
8 1.3v
I have an oscilliscope and can report back any directed tests.
Any help would be appreciated.
Thanks!!
