I've got a Sega Master System hooked up to a Micomsoft Framemeister to capture game footage. I'm getting audio but no picture. I've done some troubleshooting to narrow down the problem, but I'm getting conflicting results.
It's connected like this:
Sega Master System -> RGB SCART cable -> Euroscart to 8 pin mini-din adapter -> Framemeister -> TV
The TV is getting a signal from the framemeister which is just a blue screen with the words "No Input". This is what the framemeister ouputs when it does't get a signal. But audio is coming through fine.
A couple times, for a brief moment (1 or 2 seconds) I got picture. But the image was distorted. The distortion looks like bad antenna reception.
I checked the euroscart to mini-din adapter for continuity and that the correct pins are connected. Everything checks out. No shorts, and good continuity.
I haven't checked the RGB SCART cable for continuity directly, but I've been using it with my monitor for a month now and picture/sound come through no problem. So I don't know how the cable could work with the monitor, but not the framemeister.
Sega Master System RGB output over the RGB SCART cable works fine when connected directly to the monitor.
I've tried the exact same setup except with an N64 and a Sega Genesis. Picture and sound come through fine.
Suggestions?
