AC transformers for heaters/filaments also cause a surge that burns out vacuum tube heaters at turnon. A solid state heater supply with a LM317 can have a slow startup by adding a single capacitor and eliminate this problem. A solid state heater supply requires these days very few components, a LM317, a 220-ohm resistor, a rectifier and filter cap, a small cap, a voltage setting pot or resistor and an electrolytic cap to bypass the setting resistor for slow startup and a small cap at the output. The metal chassis can be used as a heatsink.
Pre-amps do not require huge tubes that require a very large current just to light them up.
AC transformer wires snaking through very low level input signal areas of your chassis can induce hum into to high impedance tube inputs.
The D.C. heater power supply can also be floating or even biased.
The filaments/heaters have a very much lower resistance at turn on and this creates the bright flash seen at turn on as the heaters are stressed by the turn on surge.
That said,tubes were used in the millions over tens of years without any noticeable incidence of heater burnout due to turn on surge.
The most common reason for replacement were loss of cathode emission,& heater to cathode leakage.
(Most tubes used were of the indirectly heated type)
Older tubes which you obtain may be "pulls" removed because of the latter problem.
Heater to cathode leakage can cause hum in the wanted signal,but if you did use a regulated dc heater supply,you may be able to use otherwise unuseable tubes.
Directly heated (filament) tubes had problems with uneven emission due to one end of the filament being at a different dc potential,but this is unlikely to occur with dc operated indirectly heated tubes.
People seem to be incredibly "wussy" when it comes to tube power supply voltages.
100v & above power supplies are not a hazard,providing you use a bit of care.
To add a bit of perspective,vk3ye was making tube Transmitters when he was about 12 years old!
You mainly need good filtering with tube HT supplies---voltage regulation is nice,but not essential
