Author Topic: Turning a rotary knob with stepper motor  (Read 4310 times)
Offline namluTopic starter
« on: July 12, 2014, 09:29:38 pm »
Hello.
I want to turn a rotary knob of a test equipment with a small stepper motor:
https://www.google.co.il/search?q=rotary+knob&client=safari&hl=en&source=lnms&tbm=isch&sa=X&ei=HafBU_m_N6jG7Abu4ICADg&ved=0CAcQ_AUoAQ
It is about 2 cm in diameter.
My question is: how do I hold it with a stepper motor? How could it be attached?
Any idea? Is there any known thing I can just put on top of a knob and attach it to the motor?
Thank you.
Sent from my iPhone using Tapatalk
Offline BillWojo
Re: Turning a rotary knob with stepper motor
« Reply #1 on: July 12, 2014, 09:34:58 pm »
Do a search for shaft couplers. You will need to know the diameter of each shaft.
BillWojo
Offline rob77
  • Country: sk
« Reply #2 on: July 12, 2014, 11:16:16 pm »
+1
don't even think about trying it without a shaft coupler ! you would kill the sensor (pot, encoder...) attached to the knob. the shaft coupler is a must to absorb any misalignment between the shafts. btw.. i'm talking about misalignment in orders is tenths of a degree or tenths of a millimeter off-center... so you have to "perfectly align" even when using a shaft coupler.
Offline Stonent
« Reply #3 on: July 12, 2014, 11:19:50 pm »
If the encoder clicks between positions you'll also need to make sure the stepper and encoder have the same number of clicks per rotation if you need to accurately set a position.
Optical encoders like the ones used on ball mice do not click.
Offline elliott
« Reply #4 on: July 12, 2014, 11:24:11 pm »
A piece of rubber hose works pretty well as a coupler for low torque applications.
« Reply #5 on: July 14, 2014, 09:11:49 pm »
Hello guys.
Thank you for your tips. After looking in ebay, I ordered rubber hose:
http://www.ebay.com/itm/221234449225
The size looks good and it actually may work.
I will wait a bit with shaft couplers.
Sent from my iPad using Tapatalk
Offline DavidDLC
« Reply #6 on: July 14, 2014, 09:25:15 pm »
Hello.
Thank you.
I'm interested to know why do you want to do this. Can you explain ?
« Reply #7 on: July 14, 2014, 11:19:20 pm »
Hello.
I need to go through the entire scale of an old test equipment, in order to debug a FPGA design. It takes about 10 minutes each time. I hope to do it automatically.
