The offset current they're talking about is due to the output of A and B not being *exactly* the same. Whenever there's a non-zero voltage differential current will flow according to ohm's law, so the resistors are limiting the current which flows between the two opamp outputs, that is Iab = (Va - Vb)/(Rbm1 + Rbm2).
I hope that's what you were asking.
