Hello everyone, hope this qualifies for the beginner category.
I've got lots of experience in circuit design, but virtually
none involving high voltages or negative voltages.
I'm trying to design a dynode control circuit for a Hamamatsu photo multiplier tube (PMT). My objective is to be able to adjust the PMT gain over a wide range, by increasing or decreasing the number of enabled dynodes.
You'll see by referring to p.98 (figure 5-20) of
http://www.hamamatsu.com/resources/pdf/etd/PMT_handbook_v3aE-Chapter5.pdf there is a suggestion to short a certain number of dynodes.
My quandary is how to handle this. My supply voltage to the PMT (aka -HV) is
-500V and I want to be able to enable/disable each dynode remotely, either via a 330K resistor on the divider segment, or a 0 ohm to short it to the adjacent dynode.. I'm guessing some BJTs or FETS, coupled with microcontroller GPIOs may be a good start here, but I've got lots of uncertainty.
Any suggestions or ideas?
Thanks!
Gary
