Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
Ultra low power clock generator for portable devices
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Ultra low power clock generator for portable devices (Read 2634 times)
DanioIO
Contributor
on:
September 25, 2014, 02:07:41 am »
Im trying to make a simple mp3 player based on ADAU1761 DSP Audio Codec, but i stopped at a small problem, this ic requires a clock generator, but i checked so manufacturers and they consider 4mA as a low power clock generator. I can not used 4mA for a clock, is there a lower current solution? I need a clock in 8-27MHz range.
Example low power oscillator:
http://www.sitime.com/products/datasheets/sit8008/SiT8008-datasheet.pdf
ADAU1761 datasheet:
http://www.analog.com/static/imported-files/data_sheets/ADAU1761.pdf
Logged
Marco
Super Contributor
Country:
Re: Ultra low power clock generator for portable devices
Reply #1 on:
September 25, 2014, 03:35:19 am »
Bit of googling for low voltage/current oscillators finds the
ASD series
from Abracon and the
HK series
from Mercury Crystal.
That said, why is it so important? Even driving in ear headphones are going to make it pretty much irrelevant.
Logged
DanioIO
Contributor
Reply #2 on:
September 25, 2014, 11:22:56 am »
I found an 0.7mA solution, can i get even lower current? The 0.7mA i can achieved using a LTC6930-8.00 oscillator.
I need a low power solution for standby mode, in which i the main IC will running consuming about 7-10mA.
LTC6930 (
http://cds.linear.com/docs/en/datasheet/6930fd.pdf
Logged
Marco
Super Contributor
Country:
Reply #3 on:
September 25, 2014, 12:18:05 pm »
What's the boot time of your device? Can't you just power gate everything with a small micro (using the internal RC oscillator) and a FET?
PS. although I doubt it matters, a 12.288 MHz oscillator will give you the cleanest clock.
Last Edit: September 25, 2014, 12:20:48 pm by Marco
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
