Is this a special sensor that has a digital output? Is it safe to assume the sensor is a phototransitor because it has three legs? Based on my readings there are three lights sensors the photodiode, photoresistor, and phototransitor. Are you able to tell me what type of sensor is used on the module? I would like buy some at a cheaper rate than $5ea. I just don't know what to search on digikey.
Thanks,
Andrew
