Give it a try. Should be easy to assemble pretty quick. If it works great, if not you can reuse all the components.
Or you could take a look at this or other similar articles:
http://electronics.stackexchange.com/questions/105688/using-copper-clad-for-rf-projectsFWIW, I have been trying to learn electronics at the hands-on level since I first discovered EEVblog. It's been a pretty slow and methodical (often tedious) process of studying plus trial and error but with feedback from other EEVers and other learning vectors (the Internet is of course a magnificent resource) the journey has yielded steady if not rapid progress, and even though it's been kind of slow it has yielded what I consider to be significant progress (at least compared to where I started). But even though Ohm's Law, resistors, LEDs, DMMs, batteries and DC power supplies, transistors, capacitors, inductors, antennas, spectrum analyzers, signal generators, oscilloscopes, AC vs DC, impedance and reactance including phase angles and more have become increasingly understandable the concept of ground remains consistently among the most commonly used and yet the most elusive. I don't know what I'm missing but I know I'm missing something, probably a lot, and probably some things that are very key. Good luck with "ground" and everything related (which I have a hunch is most of electricity).
(just to be square, that's me - but I've found it helps to be a little humble and be able to laugh at yourself when trying to learn electricity)
PS, I think understanding ground is also important to personal and test equipment safety - two other great reasons beyond DUT performance and safety to figure out ground and it's various implications sooner than later
