Hi
Ok, lets back up to series circuits for a bit:
If I put a battery, a light bulb and a toggle switch all in series, current only flows when the toggle switch is closed. All the current going through the switch goes through the light bulb. It also all goes through the battery. It does not matter what order the elements are arranged in.
Next I take my circuit that is floating in space and pick a single point to put a sticker on. The sticker says "ground". I can put the sticker on any wire in the circuit, but only on one wire. Putting a sticker on a wire does not change the way the circuit works. Calling a wire "ground" does not change the circuit.
So far ok?
Bob
