Hello,
I'm trying to get a solid understanding of basic electronics. I got a hold of a used copy of the second edition of the The Art of Electronics and the Student Manual for the Art of Electronics, and I'm planning to work my way through all the labs. As I set up the first lab, which is basically verifying Ohm's law, I got some strange results.
The lab is basically to measure voltage vs. current for a 20k resistor. Not having a 20k resistor, I put two 10k resistors in series and constructed the circuit as shown in the first image - easy enough. I was also using an adjustable power supply and taking measurements at 0.5V intervals. As I noted the results, I got twice the value of the current I expected each time. For example, for 5V I expected to get 250 uA, but instead I got close to 50 uA. I've posted a plot of the values I was getting, and sure enough I confirmed the linear result for Ohm's law, but the values of current appeared to be always 2x the expected value. I measured the resistance of each of the resistors and I got ~9.9k.
What gives? Maybe someone can point out something obvious I may be missing.
