I've got this battery powered amplifier that sounds surprisingly fine and is rather loud when hooked up to a 6 Ohm HK195 driver salvaged from pc speakers, but the only visible chip on the thing aside from some 1AM transistors is a TA8803N - HT110609
The closest thing i can find is this:
TA8800N Seems like a rather odd chip to use?
attached is a pic of the board in question:
The only component on the reverse side is a 220uf 6V capacitor connected directly to the power in, which used to be 3xAAA but i've since attached a usb lead to it. If anyone wants a pic of the reverse side to see all the traces, by all means i'll post it.
Edit: oh, right. Power button is middle, volume up is left, volume down is right (board is upside-down so chip is readable)
