Author Topic: Units of X/Y/Z  (Read 1352 times)
Offline asg32000Topic starter
Units of X/Y/Z
« on: January 19, 2016, 03:03:07 am »
I am working with a pressure sensor that has a "Sensitivity" rating with units of ?V/V/mmHg.  I believe ?V is the output voltage, V is the excitation voltage (for the wheatstone bridge), and of course mmHg is the pressure you are sensing.  My question is: when trying to calculate the expected ?V output, would I do something like this?
(?V/V/mmHg sensitivity rating)/(excitation votage V * pressure in mmHg)
You can't just do standard "order of operations" to calculate this, right? e.g. X divided by Y, then divide that by Z?  X/(Y/Z)...?
Any help would be appreciated.
Offline rich
Re: Units of X/Y/Z
« Reply #1 on: January 19, 2016, 03:52:22 am »
Vout = Sensitivity * Vexcite * pressure
Think of as if you increase any of the 3 variables, you would expect the voltage to increase.
Or use the units as a clue to get:
Sensitivity = Vout / Vexcite / pressure
and rearrange with algebra from there:
Sensitivity = Vout / (Vexcite * pressure)
Sensitivity * (Vexcite * pressure) = Vout
Re: Units of X/Y/Z
« Reply #2 on: January 19, 2016, 01:44:37 pm »
Thanks!  That shouldn't have been so hard...  Somehow I forgot to think about it algebraically.  I appreciate it.
