I've got a PIC MCU that has RTC functionality programmed into it and uses a typical external 32kHz crystal. The core is clocked using the internal RC oscillator.
In the application I will be using it I do not require the RTC functionality. What is the optimum (electrically) way to disable the internal part of the oscillator? I do not have access to the firmware.
I have attached a schematic of the Pierce-type oscillator.
How about a pulldown resistor to ground at the input of the inverter? 100k?
A
