I'd like to make an USB charger. I can break out some USB port from old PC parts. I am thinking of just connecting 3x rechargable AA batteries (4.5V) but a USB port is usually 5V, I assume it's not a problem to go under 5V ? Should I place a voltage regulator as well ? (P.S. I have no experience with a voltage regulator, if the voltage is below the specified voltage, will it go up to that voltage or only limit to that voltage ?)
Thanks in advance !
Axel
From how you worded this, sounds like you want to use three AA rechargeable to power a charger that charges perhaps Li Ion cells.
3 AA rechargeable would be 3.6V nominal. NiMH is only 1.2V per cell. You actually have anywhere from >5V to below 3V. Most of the capacity will be delivered at or around 3.6V for good cells like Eneloop. Other cells may deliver most of the capacity below 4.6V.
So, with 3AA NiMH, you better use a charger setup that operate down to 3.0V since most of your capacity would be below 4V. A booster is a good option too but it is not efficient. You would loose 40% of your power to boosting, but you would have steady 5V 750mA-ish for (if your cells are good) around 30-45 minutes, or even an hour if your cells are really good.
I made a 3AA "power supply and charger" after an extended storm power outage. Using a Chinese 2577 booster board with 3xAA Eneloop. It powers 4xlow power LED without booster, or G4-5050smd 12V-1W lantern, or a USB plug so I can adjust the 2577 to get 5v to charge my phone on emergency. (Crazy set up, since it is for the "last stand" stage of an emergency when even my my car is low on gas and my 12V SLA's are all flat,. For such rare use, I went for throwing together something cheap rather than something nicer.)
I can get days of 4xlow power led, or 2 hours of 12V-1W light which even with boost went down to 9V in 2 hours; or adjust the 2577 to 5v and power my charger. My charger is at about 500mA. If I recall, it was around 1 to 1.5 hours before the 3xAA drops too low to power the booster.
You need to test endurance for your batteries for exact time of how long you can run the charger.
With 2000mAH Eneloop, the math would be total power @5V@60% boost efficiency = 0.6*2000*3.6/5 =864mAH @5V total;
With prior tests, I know Eneloop does delivery at least 80% of it power at around nominal voltage or above, so 80% is 691mA for an hour. The rest is gravy.
Good luck with yours.
Rick
