In some older episode, dave mentioned the idea of a USB-powered lab power supply. The idea struck a chord with me, even though Dave seems to have abandoned it. I like the idea because it would be somewhat of a challenge to implement. I could take parts of Dave's PSU suggestion and modify it to make it work from USB. At first glance, it seem like a nice idea, because USB is ubiquitous, you'll find cheap chargers or a nearby laptop everywhere, and most projects don't need all that much power. I mean, even the arm-based GSM-and-OLED-equipped thingie I write software for at work stays under 1.2 Watts most of the time.
So I've been mulling over how to design such a PSU. I'm thinking the power supply must be isolated from the USB port, in order to protect a laptop if things go wrong. So an isolated transformer-based DC/DC module would be the first part. I found some parts from Analog Devices (their isoPower devices) that do just that. Then a step up converter to get, say, a 15V from which the 0-12V working voltage could be derived from, maybe using buck/LDO combination for efficiency like Dave uses in his current lab power supply design.
Now, the problem I have is that just sketching this in my head results in an overall efficiency of just about 50%. The isolated dc/dc modules seem to hover around the 70% mark, and the following voltage transformations eats into the budget some more. Now, a standard 500mA USB port doesn't provide all that much power, and a mere 1.25W (2.5W times 50% efficiency) isn't all that much, I'm thinking the whole thing would be pointless then. 2W of output power off a standard USB port would be nice, I hear you can fly to the moon with that (and ouf course, if some charger delivers more, all the better.)
So what I'm asking you is: do you have any clever ideas to improve the efficiency of a circuit that transforms an input voltage of 3.6-5.75V (which seems to be what USB ports output under varying load conditions) to an output voltage of 0-12V? Eventually, I'm hoping to figure out how to achieve 80% overall efficiency.
This is really my first forray into analog electronics, I've only done digital stuff so far, mostly ignoring the analog side apart from some simple filters do get rid of undesired ringing and so on. If you think this is too advanced, I'd like to hear your thoughts too. Cheers!
