Hello all!
I found that two of my power supplies (the above Anker PowerPort +1) and another Anker 24W dual-port emitted sparks when I touched grounded equipment with the micro USB plug outside shield (at the position that the shield would touch the grounded item). I measured the voltage from USB (-shield/ground) to mains earth with an oscilloscope - which showed about mains AC voltage - although I could not really draw any significant current.
I was quite surprised as these are generally high quality supplies - but other power adapters I have do not have the same issue.
Finally I got round to disassembling one of these power supplies (the PowerPort +1), and find that when I remove the capacitor that bridges the primary rectified (-) side to secondary (5V USB -) , the sparking does not occur anymore. When testing the capacitor (see attachment) It shows a capacity of ~900pf - would that be within reason?. It measures resistance > 20MOhm so seems intact.
What other reasons could there be for the sparking / the capacitor conducting so much HF current? Is this expected or could it be that both of my USB devices are faulty? If so - what would be a reasonable capacitor to get (I probably won't use this one again anyway as they don't go apart easily).
Thanks for any input - would be interesting to get to the cause of this!
Best, moewu
