Thanks ! appreciate that
Your divider is still the wrong way around.
The source of 5v is from the USB as mentioned in the Datasheet so that VBUS detects and USB is connected.
Once again, where is the third ground pin coming from?
That is the Exposed pad underneath. correct the symbol by adding two more pins for that rather than appending them to GND.
