Why on earth use a heat sink at all, let alone 3 or 4 on a Pine64? Seems completely pointless to me. None of the chips consume enough power to make heatsinking necessary.
Unless you are talking about a different board than the quad-core ARM SBC?
– 1.2 Ghz Quad-Core ARM Cortex A53 64-Bit Processor. Executes both 64 and 32 Bit for scalable high performance
– Dual I/O expansion slots
– Dual Core Mali 400 MP2 Graphics card
– 2GB DDR3 Memory
– Integrated Display engine with HDMI 1.4a
– 10/100/1000Mbps Ethernet Port.
I received mine second hand and already had one . It does run a bit warm after a bit of use. With research and youtubing I noticed a lot of them with more than just one heat sink. I'm new in this field but thought it was odd to have so many on the other hand maybe being new I was lacking the knowledge of why they are neeeded.
So your saying it is fine the way it is and I need not worry about not having more than just the one ?
Thank you for your reply
Sent from my iPhone using Tapatalk
