LM358 is pretty slow to be using for this. Though considering ignition isn't very fast to begin with, it might actually be only marginal. But I'd like to see that done with something a bit faster, like a proper comparator. (LM393 is popular and similar, but has open-collector output, so you have to do some handiwork with the output to get the same voltage levels).
If you don't care about speed, you can hook the output right to a MOSFET gate (via 100 ohm series resistor, say), which I should think would be fine for injector drivers, if maybe not ignition coils.
