hello everyone..
I'm planning to make a batterypack of 4S2P configuration along with a BMS.and I want it to be charged using a 12V DC adapter. I also understand that the battery should be charged first in CC mode and then CV mode. Since i use a 12V charger I'm suppose charge with 4.2 X 4 = 16.8 V with the help of a boost module. Unfortunately I can't find a CC, CV boost module instead could only find a CC, CV buck module. so I'm planning to first use a boost module with only CV mode to get the 16.8V or higher and then fed as the input for the CC, CV buck module to finally use it as the charging source for the batteries. MY question is that would this arrangement works or not??
