Couldn't find a clear cut answer when looking through google.
Im using 74F ICs, and while i do know that you need to put pull down resistors on inputs, and that you should use current limiting resistors on inputs as well, according to datasheet. Should i use a resistor on the Vcc pin to keep the IC from burning up, or does it so that on its own?
