Hi, i want to use multiplexer chip for ADC. To measure voltage and current. ADC is LTC2420. As im using only one switch in it (its a Triple 2-channel multiplexer) i don't know what to do with others (datasheet not tells anything about unused pins). Can they all be grounded? As im using 2Y0, 2Y1, 2Z and S2 pins other select pins also can be grounded?
Thank you.
