I am trying to build a couple of regulated linear power supplies. What I have at hand is one large toroidal transformer with two separate (isolated, not center tapped) secondary winding. The windings are 25V@5 Amp each, and I'm not planning to draw more than 3 amps from each. I am wondering though, are there any issues if say, I am using one supply, and I suddenly switch on the other supply...will the jump in current drawn (particularly the current to fill up the charging caps of the second supply) "ruin my day" or affect the first supply's voltage? If there is such an effect, how do I avoid it? And is it generally a bad idea to use secondary windings on a transformer in this way?
Any guidance and help is appreciated.
