1. Have to turn on or off, ac load using micro-controller. Microcontroller is +5V powered.
AC load is resisitive wire of 780ohms for heating wire purpose.
2. using MOC3052, I am sending high & low on its anode, but output load dont get on/off.
3. I am not using any zero cross here, I check when measured temperature is below setpoint just send +5V on MOC3052's anode & keep high until temperature is higher then setpoint then 0V on MOC3052's anode.
Is it due to this, that MOC3052 dont get turn on or off, as I am not using zero cross?
