Author Topic: Using Triac MOC3052 for ac load on/off  (Read 2016 times)
Offline Vindhyachal.taknikiTopic starter
« on: December 18, 2017, 06:49:31 am »
1. Have to turn on or off, ac load using micro-controller. Microcontroller is +5V powered.
AC load is resisitive wire of 780ohms for heating wire purpose.
2. using MOC3052, I am sending high & low on its anode, but output load dont get on/off.
3. I am not using any zero cross here, I check when measured temperature is below setpoint just send +5V on MOC3052's anode & keep high until temperature is higher then setpoint then 0V on MOC3052's anode.
Is it due to this, that MOC3052 dont get turn on or off, as I am not using zero cross?
Re: Using Triac MOC3052 for ac load on/off
« Reply #1 on: December 18, 2017, 06:55:25 am »
ckt
Online kripton2035
« Reply #2 on: December 18, 2017, 07:03:31 am »
did you actually build the circuit ? if yes, then may be you don't have the MOC between A2 and G of the triac.
something like this :
« Last Edit: December 18, 2017, 07:05:04 am by kripton2035 »
