Hi eevblog peoples - long time lurker and first time poster here.
Soo this one has a bit of a backstory, bear with me
I'm trying to make a pirani vacuum gauge to roughly measure low and medium vacuum (doesn't need to be precise at all, just a go/no go) - the device is basically just a filament, the rate of heat loss is roughly equal to the pressure of the surrounding gas.
I've made the filament, a 20mm piece of 0.05mm thoriated tungsten wire (used mostly because it was there). The theoretical resistance is 0.58 ohm but the whole setup (jimmied onto an old BNC vacuum flange) measured around 0.7ohm-ok. I tested the filament just with a bench supply and seemed to work OK, with the power loss proportional to the pressure.
Next I started on the driving circuit - a wheatstone bridge with resistor chosen to balance when the filament is 1.5 ohms (or ~200-250C). Keeping constant resistance is good because it maintains a known temperature and the gauge is more accurate (fairly stable rates of heat conduction down the supply cables etc). So I fed the output of the bridge into a power opamp (L272M, again chosen because it was easy to get quickly before the weekend) but as soon as I switched the thing on it was start oscillating like mad- it would be stable for only a couple of seconds.
I assumed I had just messed up some connection (seems to be 95% of the problems I have is not my schematic, it's just me connecting something the wrong way...), so I tried again but still had the same problems.
I had bypassed the power and the bottom resistor of the reference side of the bridge, so I stuck another cap across the filament and then started playing with different caps from my box of mixed junk. I eventually got it stable-- but I'm not sure why(!).
I'd be super grateful for any insights anyone might have (have I done something wrong?), or if you've got any other ideas of a better way to setup the control circuit for a sensor like this? I can't think of any other ways to deal with the little tiny voltages needed to keep the thing at the right temp.
Another option would be a much longer (higher resistance) filament but within reason the shorter the better.
Thanks for any help!
