Author Topic: Variable frequency drive and common mode voltage  (Read 882 times)
Offline KemmeTopic starter
« on: November 22, 2017, 04:53:06 pm »
Hello all
Is there any way to measure the common mode voltage on a three phase motor driven by the variable frequency drive when the neutral point of the motor is not exposed?
Maybe creating a virtual neutral point with three resistors would help?
Or sum of all the output voltages ((U-V)+(V-W)+(W-U)) would do a proper measurement?
Any help will be appreciated.
http://dot2pic.com - bitmap to data array online.
Online T3sl4co1l
    • Seven Transistor Labs
Re: Variable frequency drive and common mode voltage
« Reply #1 on: November 22, 2017, 05:09:31 pm »
Yes, resistors can be used, as long as modest bandwidth is acceptable (good for line frequency and harmonics, okay for switching frequencies, unreliable for RFI frequencies).
You can also use three oscilloscope probes, and average them together (using the MATH / ADD function, assuming you can add two traces, then a MATH and a trace, together -- YMMV).
Seven Transistor Labs, LLC
The following users thanked this post: Kemme
