Then perhaps you should inform companies such as Tivoli Audio who still build domestic radios and hi-fi into wooden enclosures.
Why? I don't have any knowledge how these radios are constructed internally. Maybe the PSU is housed in a metal compartment shielding it from the wooden case. Who knows ...
I own a Tivoli model one radio. I've opened it up in order to clean a dirty volume pot that became scratchy after a decade and a half, and I can report that it has mains inside the wooden box without a metal shield. I don't have teardown photos myself, but a quick google search led me to this web page where someone else has photos of it.
http://la3za.blogspot.com/2013/12/scratchy-tivoli-audio-model-one.htmlThe first photo on that listing is showing the radio with the wooden case removed. You can see the power transformer. The mains cable is a two-wire one, with no ground lead. Note that the front and back panels are plastic, while the top, bottom, and sides (removed in that photo) are wooden.
By the way, that site appears to have been written by LA3ZA, a ham radio operator from Oslo Norway. So if this radio design is faulty, it apparently got through the regulators of at least two countries (I'm in the USA). I don't know a great deal about this area of regulations, but there's nothing about this radio that stands out to me as an obvious safety hazard.
But this radio isn't high powered, and doesn't produce a lot of heat in operation. While I don't see a problem with this particular wooden case, I would be cautious about using wood to enclose a linear regulator that could be running close to its thermal limits.
