Hi fellas,
Could you advise on where abouts, or in what sort of configuration I can fit an NTC to prevent my 8A variac's inrush tripping the RCD on switch-on please?
I have my variac plugged into the wall via an RCD and I also have an 13A RCD (10A fuse) plug socket on the front of the variac. It's getting to the stage though were I'm getting annoyed with the breaker tripping every few times I switch-on. I seem to be timing the switch-on perfectly in sync with the AC peaks
I have various values of NTC going up to 20A.
Any advice appreciated
Thanks guys
