Start ohming out between pins, and from the pins to the shield. 6 pins could be a wheatstone bridge with sense lines for the excitation, or there could be an onboard amplifier, and just power, ground signal, an identification eprom. If you get a 2 pairs shorted together, and a relatively constant resistance between everything else, then you know its the former.
