Author Topic: Video: An Introduction to Linear AC-DC Power Supplies  (Read 10179 times)
Offline TimNJTopic starter
« on: January 01, 2014, 01:18:16 am »
Hey everyone,
This is a presentation that I did for my high school electronics class last year. I never got around to voicing it over...but I finally did, and this is the result.
It's really quite long so I'll put a table of contents in it soon so people can skip around...
Anyway pretty basic stuff...
1/4/14 Here's the final version:
« Last Edit: January 04, 2014, 08:44:55 pm by TimNJ »
Offline ablacon64
  • Country: br
Re: Video: An Introduction to Linear AC-DC Power Supplies
« Reply #1 on: January 01, 2014, 06:52:30 pm »
The video was removed...
« Reply #2 on: January 01, 2014, 09:13:41 pm »
Apologies. I didn't even think I posted this! There was a video/audio sync error that I'm sorting out.
« Reply #3 on: January 01, 2014, 11:00:20 pm »
EDIT: Video is offline again to anyone wondering...Audio problems grrrr
« Last Edit: January 02, 2014, 03:45:34 am by TimNJ »
« Reply #4 on: January 02, 2014, 05:46:58 am »
Woo! Finally fixed all the problems  ::)
« Last Edit: January 04, 2014, 08:45:45 pm by TimNJ »
Offline Rerouter
« Reply #5 on: January 02, 2014, 05:59:41 am »
All in all good video, though i do agree the end bit with the switch-mode image was a bit of an extreme example  :o
crack open a 5V phone charger and you can see just how few parts can be used at the other extreme  ::) (though i should note these circuits are not normally safe or very accurate)
for those reading, a switch-mode can be something a beginner can approach after building a linear or 2, picking a chip with a built in switching element makes things a lot easier, just following the few calculations in the datasheet to work out the sizes, such as the inductor and feedback network (higher frequency ones can need a capacitor in the feedback loop to "shift the phase")
« Reply #6 on: January 02, 2014, 04:58:37 pm »
Rerouter thanks for the comments. I guess I wanted to make a point, though I probably could have found a more typical example, say with an MC34063 or something.
After watching some of it, I realize I got a little sloppy with my wording, but hopefully its understandable.
Offline codeboy2k
« Reply #7 on: January 03, 2014, 11:57:36 pm »
Yes, well done video.  I especially liked the summary block diagram of the linear supply with the waveforms underneath, I think it was around the 51min mark or so
You could just edit out the switchmode stuff, you didn't do that topic any justice by giving it 5 minutes at the end.  Perhaps just mention the other kind and point to your next (longer) video dedicated to switchers :)
How did you do the graphics?  for example, the first graphic of the AC waveform with the trace moving slowly (slow reveal) .. and the transformer windings for primary/secondary ?  I would like to know an easy to use graphic tool that lets me do that quickly, without animating and rendering each frame individually.
Offline dentaku
« Reply #8 on: January 04, 2014, 02:04:08 am »
That was better than I was expecting. I watched the whole thing because I'm still a beginner.
Offline Dave
  • Country: si
  • I like to measure things.
« Reply #9 on: January 04, 2014, 02:31:34 am »
Great video! :-+
However, you mixed up the inputs of the opamp. - (minus) is the inverting one, + (plus) is the non-inverting. Maybe you could add a YouTube annotation to correct the mistake.
<fellbuendel> it's arduino, you're not supposed to know anything about what you're doing
<fellbuendel> if you knew, you wouldn't be using it
« Reply #10 on: January 04, 2014, 03:44:54 am »
Great video! :-+
Wow did I really?  |O |O ....I'm almost about to re-upload the thing and fix it...but that might be overkill.
Offline dentaku
« Reply #11 on: January 04, 2014, 03:51:37 am »
Great video! :-+
Yup, you got it wrong the first time but named them correctly the rest of the times.
Offline Dave
  • Country: si
« Reply #12 on: January 04, 2014, 03:56:38 am »
Yep, sorry.
Nope. He got it wrong every time.
« Reply #13 on: January 04, 2014, 03:57:15 am »
Yeah I should've given switchmode power supplies a little more spotlight.
The graphics were all done in...Powerpoint! For the oscilloscope waveforms I just drew the whole wave with a curvy line tool and then did an sweep right entrance animation and it just revealed it from left to right.
The transformer was done in the same way, except I just set the timing to a higher speed and made each "wire" enter "after previous".
Thanks.
« Reply #14 on: January 04, 2014, 03:58:04 am »
Thank you!
« Reply #15 on: January 04, 2014, 03:59:07 am »
Yep, sorry.
Shucks I'm going on a trip to New Orleans for the next week....maybe I'll try to bang it out before I go to bed...
Offline Dave
  • Country: si
« Reply #16 on: January 04, 2014, 04:01:51 am »
Let me guess... Mild case of OCD? I know just how you feel, mate.
« Reply #17 on: January 04, 2014, 04:02:05 am »
If I'm going to reupload...should I leave out the whole comparison of linear vs switching?
« Reply #18 on: January 04, 2014, 04:02:44 am »
I'm not sure, but I wouldn't doubt it.  ::)
« Reply #19 on: January 04, 2014, 05:06:02 am »
New video will be here when it goes online:
Thanks for the pointers. Hopefully this is the last time I upload this video!
« Last Edit: January 04, 2014, 05:37:41 am by TimNJ »
Offline Dave
  • Country: si
« Reply #20 on: January 04, 2014, 05:15:14 pm »
Looks good now. :)
I like the clarity of the audio. What recording equipment do you use?
« Reply #21 on: January 04, 2014, 08:42:54 pm »
Hey Dave. I use a Blue Snowball mic and a pop filter. Its got a built in ADC and it runs off USB so its plug and play.
Offline filip_cro
  • Country: hr
« Reply #22 on: January 04, 2014, 10:45:04 pm »
Ok now make video about advanced power supply with feedback trough opto-coupler and chopper transformer. I didn't learn about those in high school but I want to know more  :-+
Offline Abstr7ct
  • Learner
« Reply #23 on: January 04, 2014, 10:50:05 pm »
May I ask what software you used to create the slides?
« Reply #24 on: January 04, 2014, 11:07:31 pm »
Filip,
Yikes! I'm only a freshman engineering student haha. I do know a bit about that actually...but as far as being able to teach it, I'm not so sure.
