nice video. +1 and thumbs up!
questions:
1. in optical frequency combs (with which I am more familiar) there are two parameters, an offset-frequency, and the repetition rate. the comb teeth are at:
f_out = f_offset + n * f_rep
Are you saying that the offset-frequency of an RF-comb-generator is always zero? i.e. the teeth are exactly at:
f_out = n*f_rep ?
2. If you put a narrow-band filter around the n:th harmonic of the output, you'll get more or less a sine-wave at n*f_rep.
Is this n*f_rep sine-wave always phase-coherent with the input? i.e. there are no cycle-slips and there will always be n cycles of the harmonic for each cycle of the input waveform, and the relative phase will not drift?
This has to do with my first question, since in optical frequency combs you need to use phase locked loops to stabilize both f_offset and f_rep in order to get phase-coherent output.
AW
