So you mean a virtual ground, in the context of a differential amplifier?
It actually isn't 0V, just very close to 0V because the amplifier has a very high gain and uses negative feedback, to keep its inputs at the same voltage, which is normally 0V. In reality, the voltage at the virtual ground is simply the amplifier's output voltage divided by the gain.
