I post it here because i am just embaresed that i don't know it
situation is simple:
single power suply, ground at 0V and positive rail at 24V
i was thinking about making 4 tda2030 output stages for 4 separate 4 ohm speakers ~10W each
i made first power stage, tested it, and i begin to think. can i use virtual ground from this power stage to bias other 3 or should i make 4 separate resistor deviders to bias each tda chip biasing as its own thing?
not that i want save 2 resistors per chip, but i was wondering how much would single common virtual ground drift and distort inputs offor instance silent at this moment channel?
