Author Topic: Voltage Drop to a Readable signal  (Read 1194 times)
Offline Instro_SparkTopic starter
  • Love the Smell Of Solder In The Morning
« on: March 20, 2014, 09:01:21 am »
Hey just wondering if someone would be able to help me measure voltdrop across a resister. At the moment im trying to measure the voltage drop with a voltage divider setup. Im actually using a trim pot so ive connected the two end pins across the resister and then measured the voltage of the wiper pin.
What i cant understand is that when i measure with my multimeter across the resistor i get a range from 1-5v but when the trim pot is connected it gives me a reading from 23v to 19v
So how would i go with getting this high reading to a much smaller signal
Ive attached a schematic below (sense resister is R10)
Circuit details
+5v
+24v
0-10v input signal converts to a 4-20ma output which allows me inject a current into a loop powered instrumentation device
Handful of opamps
Offline KJDS
    • my website holding page
Re: Voltage Drop to a Readable signal
« Reply #1 on: March 20, 2014, 12:52:53 pm »
The good news is that the circuit is doing what I would expect it to do.
To get it to do what you want it to do, then connect one end of the 250R resistor to one op-amp input and the other end to the other input. Make these connections via a pair of 100k resistors to half the voltage, so that +24V becomes +12V at the op-amp, then set it up for a gain of x2. That way you avoid being outside the input common mode voltage range.
