Indeed.
If you insist on using plain diodes to create a bridge rectifier, one sort of a hack would be to use the common cathode dual diode packages you commonly find in older ATX power suppplies, those can have a forward voltage lower than 0.5v at high currents. (You can just not use one of the two diodes in the package)
For example :
1.7$
ON Semiconductor MBR60L45CTGmax 0.55v drop at 30A per diode but around 0.4v at 10A per diode and you have two in the package, so if you connect them together in parallel then you'd have ~ 0.35v-0.4v per element.
1.6$
STMicroelectronics FERD40U50CFP max 0.5v voltage drop at 20A per diode max 50v ... about 0.35v at 10a per diode, so with two diodes in parallel you'd have less than 10a per diode, so low voltage drop.
2.8$
Vishay Semiconductor Diodes Division VS-47CTQ020PBF Forward voltage : 450mV @ 20A per diode , maximum 20v input voltage
(note: all these obviously need to be heatsinked but only some of them - like FERD40U50VCFP for example - are in insulated packages, so if you choose one that's not insulated, you'd need to use separate heatsinks or you'd need to use some insulator between them and the heatsink as the metal is connected to cathode most of the times, so without insulator, you won't have a rectifier
But seriously, if you spend 8$ on four of these, you may just as well spend 6-7$ to buy the LT4320 i suggested and four 0.5$ to 1$ mosfets, and you may not even need a heatsink.. let's say 10mOhm rds(on) x 20a = 0.2w dissipated power on a to-252 / dpaq / to-220 / to-whatever through hole package would be nothing.
