Author Topic: voltage to bidirectional current converter  (Read 1613 times)
Offline DanKalcTopic starter
« on: February 16, 2014, 10:14:22 am »
How to build a constant current generator from (-1mA to 1mA) controled by voltage. Google gives me links only to one direction current converters mainly 0-20mA. Is there a way to decaple DC from a current? I need my current source to measure impedance using 4 leads, so the current dont have to flow to GND but from lead1 to lead2.
Anyone got any idea how to build something like that?
Re: voltage to bidirectional current converter
« Reply #1 on: February 16, 2014, 10:21:46 am »
Use a differential input amplifier to do the sensing, that way you just use a current source to the ground of the supply. That is very common.
Online Andy Watson
« Reply #2 on: February 16, 2014, 10:44:42 am »
Look up Howland Current Source. You will need a pair if you want to avoid ground - they need to be matched and perfectly balanced.
