I agree, scouring > alcohol. I don't use alcohol. Scouring is the most important part of removing the grease. You're removing entire surface, all little pits/cracks which have sucked in grease. But why not add a drop of soap, while you're at it? It will prevent any bit of grease from readhering to the fresh surface you are making. Grease from your own fingers, even. (I dont wear gloves at any point, personally. I d9nt need to)
As I wrote to someone else already, the alcohol/acetone isn't really absolutely necessary - I am using it only just before transferring the toner to get rid of any potential fingerprints that could have gotten on the surface after the scouring/washing. If you are using gloves or are just careful, there is no need for it. I prefer to do it to be sure, it takes 10 seconds and I am sure the board is good to go.
But you're wrong if you think they do the same thing. The pre-etch GREATLY increases margin for error. If you use regular laminator without additional heat, you barely have enough to make the process work, at all. I wonder if you ever try to make a larger board or with thicker pour if you will have problems.
Well, it does work for a lot of people without pre-etching. All I am saying is that it might not be necessary to do it (saves a messy etching step). If it works for you and improves your yield, more power to you. The pre-etched surface is certainly more "porous" than just scoured one.
Re laminator - I think you are right on that one. I didn't modify mine yet, mostly because of laziness. After a while it gets hot enough to allow the transfer, using normal 1.6mm FR4 (thicker likely won't fit between the rollers anyway), so I didn't bother with hacking it. The multiple passes are mostly required to get the board up to temperature, because only a little heat gets on the board during the 10 seconds or so that it takes for it move through the rollers.
I made boards of up to 100x80mm with it, with fairly large pours and it worked - the largest problem was the pitting and banding in the pour areas from the poor coverage of my laser, not really the laminator once it got hot enough. Where my laminator tends to suck are the edges and corners of the board because it doesn't heat/press uniformly over the entire board. So I either have rotate the board between passes (risking smearing) or design around it, keeping important stuff away from the edges/corners.
I may still try to open it and tweak the thermostat inside, it is the basic bimetal type, so it shouldn't be too hard to get it to a bit higher temperature.
@Janoc, BTW, this is so weird to me you use vinyl method for higher accuracy. Is self-sticking vinyl that cheap? Or do you reuse it, over and over?
The roll of vinyl I am using costs about 15 EUR or so, definitely less that 20 EUR (don't recall exactly, it has been a long time since I have bought it). It is the kind used for decorating, kinda like self-adhesive wallpaper. I am calling it vinyl but maybe it is something else (perhaps some form of PVC?) - it is a smooth, shiny plastic on a paper carrier that you peel off when you want to stick it on something. Mine has a German vendor logo on the back, I think it is from d-c-fix (
https://www.d-c-fix.com/). I am using a plain white one for the PCB work, but you could likely use any color/pattern.
I am not reusing it - maybe one could do that, but it is rarely worth the trouble, with it being wet, potentially stretched from the water and lamination, etc. I just cut a piece of it slightly larger than my board, stick it on a regular paper as a carrier (that's where the self-adhesive part comes handy) and print on it. Then I cut it out and do the transfer. And then I toss it.
The difference vs Pulsar is that I can get this from a self-improvement store around the corner whenever I need it. The Pulsar/toner transfer paper I would have to order by mail, which adds another 10 bucks minimum for shipping - and I get 10 A4 sheets in one pack. The vinyl roll is 5 meters x 50cm or so, for the same price.
Pulsar doesn't have any of the problems you described. As for smearing with the vinyl, maybe you can increase your accuracy with pre-etching. This also holds the toner better if you are the penny pincher using magazine/photo paper. It will be much harder to accidentally rub the toner away when you're removing the paper fibers from your board with the toothbrush. If vinyl might smear, but it leaves no fibers and releases like magic (or like pulsar?), seems like I would be using IT for the simple, large pitch stuff. Going back to my earlier years, I used to just do 4 of every board to make up for errors. Nowadays, one will do fine.
Vinyl is definitely easier to smear because the toner doesn't stick to it so well. It also doesn't like high temperatures - if it gets too soft too fast (before the toner fuses to the board) or, worse, starts melting, you are screwed. It needs to be just soft enough to release the toner.
However, it certainly leaves no fibers (which has been my major peeve with paper - who doesn't love hairline shorts caused by these!). And when it transfers, it transfers super cleanly - there is rarely even a trace of toner left on it, everything is on the board. That may not be as important if you have a good coverage from your laser and higher resolution, but with my crappy 600dpi Samsung I need every grain of toner I can get. Furthermore, you don't need to rub it to dissolve it like the paper - I just get water between the board and the vinyl and carefully peel it off. Much faster and cleaner.
I may try the pre-etching with it next time, though - if it reduces the smearing chances, great.
BTW, there is also this cold transfer method for toner transfer:
I haven't tried this myself, though.
